tc449 problom?
seth95
I have a 2012 tc449 that just went through a whole rebuild.after recie ving it back from the shop I rode it for a quick 30-45 minute break in ride and it ran great.Later that day I went on another ride and 30 minutes into it,it begun to die and not idle.The motor was not hot nor even close to over heating ,now since then it dies after about 4 seconds of idleing.what is the problem?
Check all of the connections to make sure something isn't properly plugged in. Since many connectors need to be unplugged to take the motor out it seems like a good place to start.
we did check all of the plugs. the timing seems good also...could it be the fuel pump not pushing enough or pushing too much?
Need to make sure both tanks petcocks are fully opened and check the fuel lines for kinks and what not. There is no adjustment
First thing to do is a TPS reset:
http://www.cafehusky.com/threads/updated-tps-efi-reset-449-511.28801/
If this does not cure the problem, it needs to be plugged into an HST to check the efi components.
I believe the TC's have the "fast idle- idle adjustment" knob in place of the TE's air screw. (both do the same thing- measured air leak) Have you checked for air leaks around the intake? I've seen a couple of bikes with loose manifold clamps and and it 'll run so lean it just dies while idling, yet runs fine off idle.
