tc449 driving me crazy!!!
seth95
I have a 2012 tc449 that was just rebuilt.after breaking it in for about 30 minutes it started to have a weird popping sound and now it will not idle unless the choke is on really high and sometimes now when I attempt to start the bike the starter will hesitate for about 5 seconds then it starts.and I have tried the tps reset and it does nothing.also every ground and wire on the bike is fine?
Yes ote="Huskynoobee, post: 335013, member: 7392"]Check the relays? Intake boot secure?[/quote]
Yes everything is secure
It sounds like the timing might be off a tooth- when you say the starter hesitates, does it seem to struggle before it spins or there is just a delay before it starts cranking. I'd do a compression test next. Hope you figure it out
It just has a slight delay.also the timing and compression is perfect
If it is turning over with correct voltage, timing is proper, with a nice blue spark, compression is spec,
Only fuel can be the problem. Fuel pump, or something in the circuit.
[qfixed a plug to the throttle body but now it does it when its warm="James Patton, post: 335094, member: 12444"]If it is turning over with correct voltage, timing is proper, with a nice blue spark, compression is spec,
Only fuel can be the problem. Fuel pump, or something in the circuit.[/quote]
I fxed
Its like it only does it warm.
As it is cheap maybe just replace it. Seems these fail quite a bit and cause the issues you describe.
Tinken, how does he test this? there must be a simple resistance check for it no?
I find that it is helpful to know when the fan is being turned on by a correctly functioning temp sensor, I point my infrared thermometer at the brass coupling at the temp sensor site and the sensor I have now turns the fan on at 215F. I check to make sure that this is working before I go out on each ride, because if it's not working, I know that I will overheat.
