TC vs TXC w/tuner
jwhuls
Need some advice. Thinking of adding another 449 to do some real racing with.
Is the 2011 TC449 much more powerful than a 2011 TXC449 with a tuner on it?
Thanks
Jeff
I dont think the US website has power output specs...
My seat of the pants is that a TC449 is comparable to a broken in TXC511 w JD tuner....Ive ridden both. TC is a bit lighter and has 5 speeds vs 6 for TXC.
Um no, The TXC 511 stock has 1 more HP than the TC449 and that's with lower quality Akro. Nick raced the fastest 449 money could make. It was a TXC 511 with a powercomander 5, megabomb header, 4.1rct, port & polish. If you are going to race desert, use TXC cams, if you are going to race street or mx track, use TC cams.
Specifications
Look at page 18-19
If you look at page 11 you will see that the TC449 puts out 8% more hp than the TE449, but pay close attention to the smoothness of the power band. This is why the throttle body injection on the TE/TXC's is superior to the TC's. The TXC tbi is much more progressive and smoother. But you can add that 8% HP to a TXC511 which will yield 55HP cams alone, with the mentioned above exhaust and pcv it makes 60+ HP.
TC449=50.0 HP @ 9,300rpm TXC449 = 46.5 HP @ 9,000rpm TXC511= 51.0 HP @ 9,000rpm
Are you telling me that my butt is accurate within 1 horsepower.
Pretty much, well without the tuner. I am thinking about going to the Bazzaz tuner to get the traction control. I didn't want to use a tuner until I fixed the torque limiter. Ty has a ported and polished head for me too. Not that I need to go any faster.
thanks for all the input. It doesn't seem like much difference.
The price is too good to pass up.
Think I will give it a try. that will make three 2011's
