Tapered C/S sprockets
toolguy1
HI guys, I recently acquired a '74 250WR with the tapered countershaft. Is there a source for these sprockets? It came with 3 new ones that the guy had but I'm wondering if I need to go to a spline output shaft.
If you have 3 new ones...that should last a few decades of daily use.
They wear like...well...like the highest quality Swedish steel!
That being said, if anyone has a spare 12 tooth large taper...please let me know.
Correct, the older "small taper" has a keyway, the later "large taper" does not.
A quick measure with calipers shows the large taper bore at about 19.8mm at the inside and about 18.2 mm at the outside.
The 74 WR would have the large taper.
A few other hints:
> Make sure both countershaft taper and sprocket taper surfaces are smooth and squeeky clean before installation.
> Torque to 50 lbs (flywheel nut also...). It doesn't hurt to re-torque after a ride...
> Use the Husky puller to remove the sprocket...other methods may fail or cause damage.
> Use the Husky special tool (it hooks between sprocket teeth) to hold the sprocket to loosen and tighten the nut. Or a special vise-grip like gear holder that can brace against the frame or footpeg. Do not try to hold the c/s from turning by putting the bike in gear...you risk transferring too much force and breaking expensive transmission parts!
> There is another Husky tool...a rod with 2 bent ends that should be used when loosening or tightening the flywheel nut. It transfers the force to the frame where the rod hooks into a hole near the footpeg.
-Richard
I have a client whose 74 250WR I'm rebuilding. The clip end of the countershaft was for some reason ground away so that the normal spring clip would not hold the sprocket on. After spending a considerable amount of time looking for a 16-12-473-01, I decided to try to add filler metal to the end of the shaft and then using a grinder and dremmel tool, shave the serrations and cut a new groove for the spring clip. It turned out pretty good if I do say so myself. After: get-attachment.jpg Before: Prior to Rejunivation.jpg
