T610 turn signal flasher unit
jellyrug
Mine failed, after servicing the bike. Just did the TAT, did not miss a beat, go figure. After servicing and cleaning must have gotton water in the wrong spot.
Anyone replace these with a Husky part, or just go aftermarket?
I had the same problem. I replaced with stock, but cost $$. Later I found out it could be replaced with a cheaper aftermarket one.
Any idea which one? Eric's just went out and so he was putting mine on his to test it out and he ended up breaking mine :(
Now we need 2 of them...
Are you guys talking about the flasher relay? You can pick one up on eBay/local store for a few bucks, you dont need anything fancy just get an LED Flasher Relay with positive and negative leads. The stock one is under the left upper panel by the seat, small black box with a plug going into it. Unplug it, wire in your new one +/- and it should blink fine again, best of all if you go LEDs you wont blink fast. I couldn't get the stock one out of the rubber holder thing so I just left it.
EDIT: This one looks very similar to the one that came with my bike (uninstalled), but mine had long wire leads +/- on it, no plug. I'm gonna guess that most of these relays wont have the right plug anyways but with this one you would just cut the plug off, strip the wires and plug them into the bike side of the original relay. You dont need this exact one of course, just find something similar.
http://www.cyclegear.com/eng/product/Flash_LED_Relay/web1010332
Thx everyone, just got the stock one from Halls at $30. Guess I have to make sure it was just the relay and not something else causing the relay to fail.
