Swing Arm Bearings install, are there stops?
need2boat
Bikes a 2012 TXC310about 100 hours on it.
The Swing arm bearing should show up today from All balls and I'm going to head over to a friends house to use his press. Just want check. I can push these thru. There is no stop inside like the shock linkage. I've got no idea of how husky intended you to get them out but I sure couldn't find a clean way and just want to make sure the swing arms won't be the nightmare that was. :)
Any best practices from those of you that have done would be great. I'm good with general press use but my background is cars not so much motorbikes.
Joe
Mine is a 2010 450, there were no stops in my swingarm, bearings pushed right thru.
