Swing arm and shock bearing removal
BrettO
IMAG0692.jpg IMAG0701.jpg View attachment 23067
Hi fellow Husky riders.
I have a few pics and some info on removal of swing arm and lower shock bearings.
Firstly, it is so easy to dismantle the swing arm from your bike so I can assure you I will be using marine grade grease and repacking every 6 months for now on.
Tools I had at home that I used are a tungsten bur grinder in a drill to start and take bearing edges off then I used a stone in the dremel tool to grind out a line along the bearing, there was some minor scaring but not bad at all. You will see a crack in the bearing form and then the bearing just pulls out. Just go easy with care.
On the swing arm its self there are 4 bearings to remove. By grinding remove the 2 outside ones and then I used a 17mm long socket and easily punched out the inner ones, the lower shock bearing comes out this way also.
It took around 3 hours and was a prick of a job. have never used a blind hole bearing puller but wish I had one as another poster on here suggested.
Hope this helps.
I'm trying to remember, but I believe when I realized that there was no shoulder in the swingarm that stops the bearing (after struggling to grind/break up the first bearing on one side), I just pounded both bearings out one side for the other side of the swingarm. Like you, I used a socket. First side took me a couple of hours, second side, a few minutes.
In contrast, IIRC, there ARE shoulders in the linkage, so the same method won't work there.
Note: This was a 2009 TE250. I don't know if the swingarm is different on the X-Lites.
