Sump plug washer sizes
MotAd
i know the bolts are m22 and m14 but has anyone got the outer dimensions and thicknesses for the crush washers? wanna buy some bulk and get the right sizes and don't have any spare to measure.
cheers
anyone?? someone must have these washers knocking about somewhere...!
i've tried phoning a dealer (pretty much the only one in the uk) but they weren't forthcoming with the info. probably because they want to carry on charging me £1.50 per washer...
Since you already know the ID just measure outside of bolt head and order that size for OD. Thickness isn't that critical, just need enough metal to be able to deform some and seal. I think 2mm would be a safe guess.
_
cheers
Have been using a new leather washer every other oil change for the last couple years.
Making them with a hole punch and a hammer from fairly soft leather. Coming loose has not ever been an issue-which I had thought might happen.
Suppose if the bolts are torqued up it's all good. In 5-6000 miles I haven't had 1 problem with a bolt loosening. Quite the opposite of what I was lead to believe with owning a thumper. Good little husky.
got the OE washers through so thought i'd post the measurements for them in case anyone ever searches here for it...
M14 - outside diameter 21mm / Thickness 1.25mm
M22 - outside diameter 28mm / Thickness 1mm
