Suggestions for 2011 te310 suspension setup.
Tim Randall
Hey guys,
Just looking for some suggestions on clicker settings for my 2011 te310
I have had the springs changed to suit my weight 85kgs with gear roughly :P also done the oil and seals (5w oil)
I have set the sag on the rear. Can't remember measurement, but it was what the guy who supplied springs told me, what measurement do you guys aim for and ill check mine to that :)
I am happy with the bike but am wondering if it could be better :)
Cheers, Tim
Yea 5wt 120mm high
Set up bike to the link, tinkered with the clickers and made it sooooo good****************************************! Still a bit of tinkering still, but it's 90% there :)
I'm amazed at how much difference I would see :)
Cheers
start here:
http://www.cafehusky.com/threads/vinduros-suspension-setup-recommendations.17836/ How much oil in the forks/what level, suggest start at 120mm and you can add more through the bleeder if required to stop bottoming out, 5wt is what I used to run and 110mm in the forks.
I used the Vinduros formula. With it I found I had to go UP two weights on the rear springs and DOWN two weights on the fork springs. I can't get over how well my suspension works now.
