Stuck in the dark.
RideLI631
While I was riding the other night I stopped to take a break and when I started my te510 back up all of my eletrical stopped working. Bike runs perfect but headlight dashboard blinkers and tail light just stopped working. Was wondering if anyone had a similar problem or and idea what it could be. Checked the fuses they are fine. Thank
s so much
There is a "DC Relay" on the wiring diagram that appears to control the lighting circuits and dash separately from the ignition circuit. I'd try finding that relay and maybe swapping with the fuel pump or fan relay to see if that might be the problem. Also inspect the fuses very carefully; sometimes they can appear OK at first glance but there might be a barely visible hairline crack.
Fuses are sometimes faulty even when appearing whole. Hairline cracks. Get some spares to check and eliminate this as a problem..check relays as mentioned above
