Steering Stem Bearing
tonskiguy
Has anyone successfully removed the lower bearing from the steering stem? If so, how did you get it off the shaft? I'm sure I'll destroy the seal, I just don't want to wreck the lower fork clamp or stem. 2012 te511.
i use a Dremel. cut the cage, remove cage and bearings, then CAREFULLY slice a notch in the inner race. smack it with a chisel or thin screwdriver and it will split. keep the tool wedged in and slide it up and off the stem.
save the inner race for reinstalling the new bearing. i keep one of the outer races (one that goes in frame) as a reinstall tool as well.
I heat the bearing up with a blowtorch. It will get loose and can be tapped off, or maybe even will fall off.
