Steering stem bearing size on 2010 TE450?
Arctra
Does anyone know the dimensions of the steering stem bearings on the 2010 TE450 with the KYB forks? Outside diameter, inside diameter, and height?
The bearings are common size, if you can get your yolk out, the bearing shop will help get them off and will have better than OEM replacements. Bearings are pretty in expensive. Just remember to pack em hard with a quality marine grade grease.
