vtskier
Hi all,
Took forks off and removed steerer stem. Pounded off lower bearing. Went to put new bearing on and will not even slide on. Inside diameter seems too small to slide over threads and down to the bottom of the stem. What am I missing?
I think the PO switched front ends? Would a tc be different size stem than a te?
Thanks,
Andrew
Thanks,
Andrew
