Stator ohms reading
my_urban_chaos
The TE250 has not been charging the battery. I checked the reg/rec and it showed bad so it was changed. Battery is brand new. Next step is to check the stator. Ohms resistance across it, by the book is "ABOUT .6 OHMS". Yup, about. Nothing about how much greater or lesser, just about. My readings are telling me 1.6 ohms resistance. I know this is out of range, but is this really that far out of range? I'm not that good at electronics so I need some help. Does this indicate a stator change? That's about the only piece of the puzzle left to change. Any help out there? Thanks!!!
I have no idea about resistance, but voltage, with engine running, from each of the three legs to another should all be the same. What the number is, again, I don't know, and I think the number is less important than that it's the same value across all three legs. In other words test the voltage of each leg to each of the others. If the voltage is the same, the stator is good. If it's different on one test, the stator has a failed leg.
