Help please. My stator came loose and crashed into my flywheel. I replaced the flywheel with a second hand one that looks brand new. The stator was rebuilt using bits similar in size and soldered back in and revarnished to give continuity. Each lead has 6 ohms resistance and there doesn't appear to be any leakage. I put it back in the bike and connected it all up. The bike started and ran for about a minute. I stopped it while I got my multimeter to see if it was putting charge back into the battery. Now it won't start again. I have no electrics. When you turn the key nothing happens. You don't hear the fuel pump prime and there is no spark. I checked all the fuses. No problem there. Can the stator have caused too much current to blow the reg/Rect? It really is only repaired to be the same as the original. Any ideas on what else it could be.
Thanks in advance.
Thanks in advance.
