starters for the italian husky
huskyfrk
is there a difference in cranking power on a starter from a 250 vs a 450. wondering if they just installed the same starter on all the bikes...... this would b for a 2010 450 i have a 250 starter available....
The starter on my '11 TE310 sucks! :cry: Battery is fine so I kick it. It'd be nice to have the e-start reliable again.
The xlites have a different starter... and it's definitely underwhelming.
Ensure your exhaust valves are at the tight end of the spec (especially the left one). And the spec is a little loose IMO.
Does that serve to 'tighten up' the response? Seems like I might need a new starter at this point, but I'm severely deficient in electrical knowledge. It doesn't seem to like to turn over much at all. Are people replacing them on these bikes after 200/300hrs?
My 2011 TE310 has 272 hours (9475 kms) maybe a few extra due to hour meter stopping at 99h at each roll over. still has original starter,
L.
L.
your stock speedo hour meter is functional? (first one that I know of) Or do you have an aftermarket?
my '14 TE310R has 8000 miles and guestimating 375 hours. Stock starter is fine, but husky had updated the ring gear and worm by the end of the '13 model year.
My '12 TE310 hour meter works fine. Just wish someone had told me a couple of years ago they only go up too 99hr and then you need to reset them. Only bonus about needing reading glasses is when you reset the wrong display but it's a good thing.
hunh.
Anybody have a stock speedo that did NOT have a working hour meter? (xlite or 449/511, maybe earlier). if so, is the display set for MPH or KPH? any other weirdness noted?
sounds like the working ones stop at 99hrs and don't roll over maybe- both of which would be weird. My now gone stock speedo's odometer would not measure mileage when coasting with the engine off; also it had no internal battery (but it did have a space for one- no connections). One last weirdness: the speedo on my 2014 TE was manufactured in 2010.
