jxg
I have seen this in another thread, but I need to ask this question because I am electrically illiterate.
I am trying to determine why my fuel pump is not priming when I turn the key. I apply 12V directly to the pump, and it does run. when i turn the key, i get a click at the starter soelnoid (i have always had an issue with my starter, but this just started happening with the fuel pump). Anyway, I have tested all the fuses for continuity, and they are fine.
So here is my stupid electrical questions. I followed the manual for testing the soelnoid and I DO have continuity at terminals B - M. the manual then states:
Use a multimeter to establish
Meter scale setting: Ohm
Starter relay resistance. Standard: 3-6 .
Am I supposed to check that with the 12 V applied, or just checking for ohms? and where am I actually checking this, between terminals 1 and 2?
