Here are some of the benefits of the PC V over the PC III....straight from their website. They don't currently have the PC V for Husky, but do make and already have many retrofit units! I sent in an e-mail asking about making one for Husqvarna and will call them tomorrow!
"Fuel Moto offers Power Commander V Retrofit units for many pre-09 applications. Note that Dynojet does not offer maps or product support for PC V when used on pre-09 bikes, however Fuel Moto offers 100% product support on our Retrofit units including fuel maps and a 2 year warranty. Retrofit units will come pre-programmed and configured by our technical dept for your application, mapped for your specific mods and ready to install with specific instructions for your bike. We have a large database of PC V fuel maps which we support and this new module brings tuning to a whole new level. Benefits of the PC V over PC III USB are its smaller size, the ability to add the Auto Tune module for live tuning, and the expanded tuning features for advanced users. We have many applications tested and ready, and we will continue to add to the list of applicable Retrofit units as they become available for each model."
"Fuel Moto offers 100% product support on the new Dynojet Power Commander V. We will continue to build on our map database and we will have fuel maps for most popular combinations. For those of you with unique engine builds and exhaust setups, or are looking for live tuning the PC V will offer an additional Auto Tune module with wideband O2 sensor (dual sensors on Harley /V Twin models) which will allow you to tune in real time. We have already extensively tested this product, for more info contact us at 877-729-4754
NEW Power Commander V Basic Features List
• Reduced size from PCIIIusb (less than half of the size of PCIII)
• USB powered from computer (9 volt adapter is no longer needed for programming)
• 2 position map switching function built in (map switch not included)
• Gear/Speed input (allows for map adjustment based on gear and speed)
• Analog input (allows user to install any 0-5 volt sensor and build an adjustment table based on its input such as boost or temperature)
• With gear position input connected the PCV is capable of allowing each cylinder to be mapped individually and for each gear (for example: on a 4 cylinder bike with a six speed transmission there could be up to 24 separate fuel tables).
• Unit has a -100/+250% fuel change range (up from -100/+100%). This allows more adjustment range for 8 injector sportbikes
• 10 throttle position columns (up from 9 on PCIIIusb)
• Enhanced “accel pump” utility (increased adjustment and sensitivity ranges)
Auto Tune for PCV (all models)
• “Auto Tune” kit will be available that includes Wide Band O2 sensor(s) and control box(es). It will plug directly into the PCV and allow automatic fuel adjustments.
• It can make a map for each gear and on a Harley Davidson models it can map each cylinder separately for each gear if needed. (basic settings would make one map for all gears)
• Each map cell is individually adjustable so you can specify an exact AFR value for each area if needed."
***Quite a difference between the two units!***
