Like Houredout said above, the service manual gives good detailed instructions, including how to get the offset correct ("Put the wheel rim over the hub in such a way that the holes in the rim with the greatest inclination angle is directed against the brake drum. See fig. 10.4”). Only instruction I’m not sure about is “Assembling of spokes: Find the place of the hub where the cast-joint is in the right part of the nearest spoke attachment. See fig. 8.3. Then follow the joint up to the hole for the sprocket which is situated just in front. See fig. 8.4.”.
Anyone know what this means? ...where the cast-joint is in the right part of the nearest spoke attachment...??
this thread has got me thinking about lacing wheels by myself for the first time ever. i recently had my 76 250 spokes re-plated and decided today i would try to at least get a wheel on my 76 250 laced, then true it if it works out. following the instructions from the manual for the front wheel (which was more straight forward than the rear) i got the spokes laced. i wouldn't say it looks perfect, a few are arced in an odd way, some are tight, some are loose. it probably just needs to be worked out but some of the spoke ends protrude out the top of the nipple, while some are still below. does this sound like a good starting point to start a truing or should i rework the lacing? also, is there a specified offset for both front and rear wheels? i didn't measure it before disassembly.
