Speedo not working?
DIRTBIKE
Just noticed on my ride to work and back today that my speedo has stopped working. Not sure if the oddometer is working or not because i didnt think to check at the time. Any ideas what might be the issue? The magnet has'nt fallen out of the rotor and can't see any damage to the wiring upon a quick inspection when i arrived home but thought i'd ask incase this has happened to you or it is a common problem I also disconnected the battery for a minute or two to reset the ecu so to speak but still wasnt working on a quick test ride around the block. Any ideas?
Disconnected the battery again when i got to work this morning and hooked it back up before leaving to go home and now the speedo works again. Must have to have the battery disconnected for a certain period of time to reset the ECU.
When mine does this I disconnect, count to thirty, reconnect and all's well. I've had to do it twice in almost three years, at a random interval.
