Speedo display replacement
obchris
What brand and website is the best overall replacement for my failed speedo display, for my 2007 TE450 ?
The soldering connections for the LCD display came apart due to engine vibrations (I assume). My 2nd option is to try and repair 30+ soldering connections, which seems almost impossible !
I don't really know about your (giant) display, but on my 310r the Trail Tech Endurance II was practically plug-n-play. It works better, better ergos, better info, and uses the stock husky sender connection and mounting bolt holes. I got mine off of ebay for $45 NIB.
I made a separate LED display which fits in the unused key switch position. It worked out great, but the wiring of the stock speedo connector was involved.
good luck.
ps- you guys that are viewing this from your phones.... are these large images screwing you up? LMK.
here's a large image with 3 outta 5 LEDs shinning (FI error & overheat are off; Turn, Hi beams & low fuel on):
