sooty running
dirty_harry
hey. i have a 2005 250 te and its running a bit sooty. its sorta developed in the last few weeks and is completely blackening my indicator as well as making my nice yellow tail plastic rather black. i took my rocker cover off not long after it started getting really sooty. I found what i think was a baffle to stop oil getting down the breather pipe that should be bolted to the end of the cam shaft was no longer bolted to the cam shaft. so i took that out (the hole was over sized so i couldn't bolt it back on). i also checked the air box and found a bit of engine oil floating round in there so i thought that the broken baffle was letting oil into the airbox. so i re routed the breather hose so that it went up and over the motor to a catch can on the other side (so oil couldnt escape as it would have to go upwards). however it is still running sooty. on a positive though there is no oil in the catch can so routing up and over the engine mustve worked.
my only thought now is maybe its in need of rings. its done about 5500 kms so i dunno. do you guys have any suggestions, is worn rings a reasonable thing to think of?
cheers for your help
harry
