SMS 630 Airbox question
4l0
Hi guys i am running a standard airbox on my bike,with PU kit fitted,Twin Arrows from Husky with ECU.On the airbox there is a black plastic tube trumphet.Is it ok to remove this now on this setup.I will be getting a JD Tuner and EHS filter when i have clocked up a few more miles.Its only done 300 miles.Thanks.
it will be louder and more prone to water sucking in crossing water with little benefit as in is same as out diameter
This is what a airfilter box looks like on the inside. Brand new due to the problem with brass nuts rotating in plastic on the old one, I will swap with new and use some
copper grease on the bolts to stop corrosion and hence sticking bolt/nut.
Wonder whether it might be possible to get rid of all that (filter and box) and replace it with a traditional K&N (or similar) pod?
It's been done, but I heard it made the intake noise unbearable and caused the loss of some low-end torque...
Can someone take some pictures for me of any mods to air box,ie EHS Filter.If i fit the EHS Filter is that all i need to do.Snorkels now gone.Thanks guys
I´d like some further info on the air filter pod too (if it´s available?).
If it fits, all the rest should just be a question of setting up the JD.
  • Like
Reactions: 4l0
I recently put a stock airbox cover back on.
... and there´s a pod under the cover? What´s it made up out of? ... and howd´s it work? ... very loud? Power?
I read somewhere that K&N make up kits to order.
The EHS is just a pre-filter. The factory foam filter is still used in the airbox, the EHS just lets more air into the airbox than the factory snorkel...
Ok ... so it´s the same as mine is at the moment. I was thinkimg of getting rid ofn the whole airbox & lid and replacing it with a K&N pod.
The EHS filter is a screen that lets air in but keeps water out. Behold!
Note the dry paper towel underneath.
It does seem to give the bike a bit more grunt, but I don't know if it's enough improvement that I want to run around with a big hole in my airbox. As you can see, I get wet. :)
Mine´s too loud as it is at the moment (twin Arrows). Any more would be a tad too provocative (especially as I´m on the brink of losing my licence for a month).
