SMR511: Relay clicks but won't turn over
squid
Hi y'all!
Encountered a problem today and before giving her a closer look , thought I'd ask if you got some pointers. The thing is, I was riding my SMR today, and after stopping for an ice cream, the bike would not start. The relay clicks but the engine won't turn over. Looked at all visible wiring and the connections seemed alright as did the grounding wires. Fuses are alright too.
Had to push start the b*tch. Wasn't too easy, but she fired up, no problem.
Any ideas where to start looking?
Ground wires, first and foremost, from starter to frame, from battery to frame, remove and clean, sand with file or sandpaper, reinstall. Check voltage at battery when starter button is pushed, if it falls hard and fast, battery is probably shot.
