SMR511 Intake Snorkel
jrbbikerx
Has anyone removed this piece of rubber from above the right radiator?
It seems as though it restricts airflow more than it enhances it.
Thanks.
JRB
I ran into this when camming a Harley motor:
High HP cams have a large amount of overlap, where the intake and exhaust cam are open at the same time. The snorkel on the intake and the amount of baffling on the exhaust work to create a "balance" where the air/gas charge is suspended in the combustion chamber while both valves are open. When you remove the intake snorkel, you will need to remove a corresponding amount of exhaust baffling to try and maintain the balance. Altering the intake and NOT the exhaust will typically induce intake pops and backfires, as the air/gas charge will want to migrate back into the intake.
many have modded the airbox or put the TC lower section on and report better performance. I am leaving mine on because i love how clean the filter stays and think this has something to do with it plus my bike has plenty of power for me.
Hmm.. If I were building an SMR, I'd chuck the whole air box and put in the biggest K&N tornado I could fit. I would place sheet metal around the radiators to deflect the hot air. Port & polish the head, add TC449 cams, PCV, iridium spark plug, FMF MB TC header, header tape + 4.1...
But I'm a slow poke and enjoy clean filters. :)
