smr449 oil filter change
gopie
Gday everyone, sorry for this very basic question! Ive got an smr 449 and have just changed the oil filter for the first time. I used one of the genuine kits that included all the o-rings etc. Included with the kit was a steel washer that is not mentioned in the workshop manual. I also didnt see one come out when i changed the filter...somehow though i found the old washer in with the used oil. It looks like its a spacer to fit behind the oil filter but im not sure. I assume its not a crucial part but i just wanted to check where its meant to go. Any help would be much appreciated!
cheers!
I see the gasket in there, it might be for the drain plug, I never use it.
Cheers for the response everyone, i thought it might have been for the drain plug. Didn't want to drain the oil again just to replace it! It explains why I've suddenly developed a slight oil leak as well! Should be fine until the next oil change though.
