Smr 510 Front Rotor Options
SMR510 Rider
Hey guys, need some advice on front rotors for the SMR. I warped the stock one and didn't want to drop a lot of money, because I was thinking about selling. Bought and used stock one and now I've warped that one. Time to get a good one. Goals: difficult to warp, easy to install.
Options:
beringer street rotor. Solid disk while others are vented. Why?
Motomaster: street, seems average. Race, good warp resistance, won't work with stock caliper?
Warp 9 Apex, 5 mm, cheaper
Any experiences are helpful
Does the 510 use an offset disc? If so be careful with the Beringer's, most if not all are flat (no offset from the mount to the brake surface), my 511 had a flat rotor by 'Braking', but I believe the 510 ran an offset brembo rotor.
Another question is how are you using the bike? Track riding? road riding? in the wet? water crossings/puddles?? A common way to warp rotors is go through water after hard braking, the disc goes from super hot to being quenched...
My research has led me to believe that the Beringer and Moto-Master race are not compatible with the stock caliper.
I do road riding. I warped it while on a long curvy road, fairly fast, but not hard braking zones. No water. On the slow trails where I find water I use a lot of engine braking and very little front brake.
My options for a stock replacement seem to be:
Warp 9 Apex: 5 mm disk, steel hub
Moto-Master Street: 4 mm disk, aluminum hub
Any ideas on the warp resistance of steel vs aluminum? The expensive ones seem to use aluminum. I know aluminum dissipates heat much more quickly.
I have a like new OEM brembo rotor from my 09 smr that i would consider letting go. Let me know if your interested and we can come up with a price and shipping.
Thanks
Jake
Thanks for the replies. I was told that the Motomaster Flame disk would work, so I ordered it. But after a month I still haven't received it. Now they are saying they don't have any in stock and it will be awhile. I'm requesting a refund and going with the Braking disk. It's also aluminum carrier and 5 mm. Hopefully, it will bolt right up with no issues and it'll be a good buy.
Update: I bought the Braking disk off ebay and am really happy with the fit and finish. Works great so far. I haven't put enough km on it to say whether it's more warp resistant than the stock one, but it looks more beefy and better made.
