SM630 sprocket size
Erik Italhusky
Hi Guys,
I have slowly started modding my 630. PU kit is done.
FMF pipe on its way and I am still considering a PC or a JDJetting Power Surge 6.
However I also want to change my sprocket size. Wondering what you guys are rocking? :)
I have the FMF on my TE 630 with 3.0 gearing, 15/45. I am 100% happy with it for dual sport use. I will not be changing it. Others with a SM like yours will have better gearing advise. I have iBeat and have the bike running good with it currently at 105/110/120. If you have iBeat it seems a PC, JD tuner etc. is not needed. Do some reading in the iBeat and TE 630 dyno threads and you may forget about a piggy back efi tuner. :popcorn:
Yeah, my plans have changed slightly now the Arrow kit is available again. I'll probably just buy this and the sprocket. I think this is the easiest and maybe even cheapest option (I can order without VAT). But thanks for the sprocket advice!
Yeah so i have the Twin Titanium Arrow kit with ECU from special parts catalog, the P/U kit, put 5 2" holes in air on cover, and have the Bazzaz Zf-I Tuner, and I run a 42T supersprox red rear sprocket and I live in the Greater Los Angeles Area and my SM630 has been sole mode of transportation for last 3-4 years and couldn't have been happier with my choice I like cruise 70 miles an hour on 5400 RPM and 6100 RPM for 80 miles an hour!!! Hope that helps
M
M
Thanks for the info mate! I think I will copy your setup. It seems you use your back for the same purposes as I do. :)
I'm running supersprox 16/44 Arrow Exhaust Gutted air box with power commander and autotune upgraded my rear rim to warp 9 5"
So what was the motivation to go up so much in the rear if you were just going to go up in the front too?
I run a 15/41, which is almost exactly the same ratio but lets me keep the chain guide/case saver...
