Slips out of gear
Railit
Hey Husky fans. I have a te 310 2012 bought it with 1500 km on the clock, did some trail riding for a few hours, then decided to do oil and oil filter. I replaced the oil with Motul 300v 10w 40 fully synthetic, now when the bike gets hot it slips gears mainly out of 4th 5th and 6th would the oil have anything to do with this its got me stuffed as the oil was not cheap. Any help will be appreciated thanks .
Not quite sure what you mean by slips out of gear? Is it jumping into false neutrals between gears, or jumping from one gear to another, or the clutch slipping?
The oil will have no effect on the first two, but may on clutch slipping. Generally if an oil is causing clutch slip, there is something wrong with the clutch anyway.
Thanks for the reply it is jumping down a gear. But on the weekend I could feel the clutch slipping at higher rpm so I striped it,all looks good no wear so I assembled it and put mineral oil 10w 50 in and road on Sunday all seems ok now, but time will tell.
