..he suggested getting a 630 stand and have it lengthened at a welder. But if a few of us got together perhaps Ken would make a new batch?
The 610 stand that broke can be fixed and reinforced. I'm still running my modified 610 stand, and it was the prototype for the "production" stands. If you look up my original thread you can see how I split a tube and welded it on to reinforce the weak point. For my prototype, I welded on a stop plate. However, I have a batch of raw stop plates that could be used on any 610 stand that has the same foot peg bolt pattern as the late model 610/630 bikes. It may or may not match up with the early steel 610 stand, but it is worth a try.
No plans to make any more stands.
It has been through a couple iterations. First made it long as the original OEM stand was too short allowing the bike to lean too far over. Then had LTR modify and lower the suspension about an inch so had to shorten it. It just seems sturdier than the original stand plus has a larger foot print.
No, the angle is the same as the original. After I had the suspension lowered I cut the foot off, then about 3/4 - 1" off the lower end and welded the foot back on. I made the kickstand tighter on the frame bracket which helps make it more stable than the OEM stand.Did you have to modify the angle to allow passing the swingarm? Or cutting it and welding a plate was enough?
I have a 2008 TE 610.Thanks for the tip. What about your bike. Is it a 610 or a 630?
