Shorty clutch lever for 511?
Suputin
Anyone have a source for a shorty clutch lever for the 511? I'd like to go one finger if possible.
i've used ASV in the past on my yamaha and they were decent enough - not quite as good for a "shorty" as i had hoped, however
http://midwestme.com/
check these levers out - if you have a brembo MC, then the brembo lever works. they are the nicest I have ever experienced, and perfect for those of us that use only our index or index/middle fingers to operate levers
one of the brembo levers comes with an extra "rod" to use in the master cylinder if the stock rod in there isn't long enough (or short enough, not sure). I ordered the one that comes with the extra rod just in case, but didn't need it. the lever is the same. the only difference is if you are getting that extra piece. for the 310, it wasn't needed.
