Bigbill
I been thinking of using a shortened '86 swing arm with dual shocks. I'm thinking of a z structural cut and rewelding it in the area of the twin shock mounts. I haven't figured out how much to shorten it yet. This is one bike that's going to be a twin shocker, left kicker hybrid butt kicker. In the past I did install a single shock swing arm in a 82 cr frame. It worked but I did extend the wish bone by cutting it and drilling and tapping it so I could adjust it to the proper length till the swing arm arc'd correctly. Once the swing arm had the proper degree of motion I locked the jam nuts with forever loctite.
I regret now 15++ years later not recording what I did. Have pics I just found.
My plan is to use a 420cc cylinder on a 430 crank on a 430cr newer case. A '87 cr500 front end with disc brake. The rear '86 swing arm. On a '81 250cr frame.
After the holidays ill look for a TIG and a MIG welder I can piggy back off my gas engine 200amp/100% duty cycle Hobart portable welder.
