Short roll of carbon fiber showed up on door step today...
ascribner
So I thought I would throw down a some quick heat shields...
I will update when they are trimmed, clear coated and mounted on the bike.
So... are you now making parts as a side business?
(you forgot to resize the pics again :D)
I am making parts for my bike. These are one-off pieces that I am making with a "lost mold" process. Easy and quick. For what these sell for in comparison with my day job, selling these is honestly not worth my time. I do it because I enjoy building stuff.
(I did not forget, I'm just lazy at the moment :-P). I share these links with friends and do not want to make them register to see the pics, which they do if I attach them to the post.
Looks good and what is the process of making these parts out of this fiber?
I will describe the process. If there are truly enough people on this site interested in how to make some custom, one-off heat shields, then I will do a write-up. This whole process will take me less than two hours.
Create the shape you want around the pipe. The easiest way I found to do this is is to take a 4" pool noodle and cut it in half.
Zip tie the pool noodle to the pipe firmly so it does not move, but not too tight that it completely deforms the noodle.
Duct tape is your best friend -- even epoxy resin will not bond to duct tape. Take duct tape and cover the noodle horizontally (parallel to the ground) from top to bottom.
First, make this out of fiberglass. Take some vacuum bagging material (resin does not stick to this. Cut your fabric to the size you need, I used 6 layers of 5.7oz. Pre-impregnate the cloth with the correct amount of resin. Let the resin sit until it reaches a B-stage (still curing, still a little bit tacky, but no longer "wet").
Form the B-stage fabric over the pool noodle.
Peel off the bagging material.
Make any final adjustments and let it cure.
Trim the piece to final fit.
Sand the surface smooth and flat.
(I used an orbital sander for trimming and sanding)
Clean the surface with acetone (wearing gloves as you do not want this to contact your skin -- on that note, ALWAYS wear gloves -- as a note, if working with resin, do not clean your hands with acetone, acetone immediately dissolves the resin, but is also highly absorbed through the dermis and you run the risk of having the resins directly absorbed into your body -- you have been warned.)
Cut your carbon fiber to size and laminate the surface with a layer of carbon.
Let the resin B-stage and spray it with a couple heavy coats of clear (this bonds the clear coat to the still curing resin with no further prep needed).
Allowed it to finish curing.
Cut, trim and polish.
Done.
I have the rear one mounted. I have to find some M18 bolts for the front heat shield. I found the spacers though.
