I just finished installing an Athena 310 kit on my 2006 TE250. After running the bike for a bit I noticed a small amount of oil seeping from the base of the cylinder. I had previously installed a big bore kit on my KLR650 and I applied gasket sealant at the base of the cylinder but I didn't do that on the 310 install because the instructions didn't mention it.
Has anyone else had some seapage around the base gasket after the 310 install that resolved on its own? Or will I have to go through the whole process again to apply gasket sealant?
most probably it leaks at the front left side. The base gasket is very thin in the area of the distribution chain housing. Putting the cilinder back on you will have most probably moved it a bit when aligning and trying to keep the distribution chain out of the crank case and in between the chain guides. Before reassembling and mounting the cilinder head, carefully check the gaskets.
