Kenneth Webb
Livin' It Up!
'Finished installing my new Safari tank today. I have to say that putting one on the WR was much easier! There is barely room for the fuel line to fit over the frame, and it has to make a radical bend to be inserted into the pump body. That's a little worrying and I hope it doesn't stress the fitting or the pump body too much. Maybe a 90 degree fitting would work better, and I'll look at that when removing the tank for the valve adjustment. The pump pickup had to be bent quite a bit to fit into the tank but I just chucked it in the vice and bent the pickup bar. Then there is the lower brace. No way it would fit without quite a bit of grinding. Grind, fit, grind, fit, grind some more. The main wiring harness on my bike was on the front of the down tube, and now it has to run in front of the brace, just kind of hanging out there. To get it to the back I would have to remove the left header as there is not room to slip it by. But, that's a real hot spot and maybe I'll just leave it up front, with some electrical cable armor. OK, all my bitching is done. The tank looks good (white) and it is noticeably narrower than the Safari on my WR250R. It doesn't look like an aftermarket tank to my eye, although I sure would like the bottom section blacked out. Still thinking on that and doing some testing on auto wrap material.
