Hi,
I have a peculiar situation with my '07 SM610's jetting. Got the bike used about a year ago. It was well taken care of has bunch of stuff on it including the Leo Vince can and they guy, second owner, tells me that the previous owner bought the bike off the showroom floor with the pipe and jetting already done from Bill's in Salem, OR. Bill confirms that if that was the situation they'd bump the main up to an 185. Strap the bike to the dyno and it's lean, about 15:1. Disassemble the carb, the jet was a 175. No problem, the tuner suggests a 195 main (a very reputable local tuner). I throw in a 195 main, 45 pilot, wire the accelerator pump together, time it, fuel screw is two turns out, unplug the TPS, and put in the recommended iridium spark plug. Bike starts easily, idles great, certainly feels better on power, and rides much smoother. Put it on the dyno again, it's running even leaner, about 16:1. Huh?! Everything looks great till it gets on to the main jet.
My thinking is and I've not had the time to confirm it is that the main jet I got, not a genuine Keihin one, is not machined correctly. Aside from replacing it again with a genuine one, what else could it be? Carb is very clean, no debris or deposits to be seen anywhere.
Before I tear into the carb again, for the 20th time, I wanted to see if any of you have an idea of what I should be looking for.
Thanks,
D
Thanks,
D
