Ripped Throttle Body Boot & Engine Cooling Q's.
Jerryn206
I ride a '10 Husky 510 SMR. Any else have this issue? My bike is at just above 3100 miles and she died on me at a light, then wouldn't start. Pushed it to a parking lot and saw this! :O It ripped from every single fastening location. I ride my bike long distances and have a feeling the high engine temps for extended periods of time is what caused the boot to fail. Going to look for some aftermarket solutions but I doubt there are any, so I'll probably be ordering a stock boot to replace it.
Also, I notice my engine/trans cases get extremely hot. I don't know if this is normal, this is my first "street" bike. What do you use in your radiators? Coolant, water, water wetter? Any aftermarket oil coolers for these bikes?
Are you running stock gearing? If so, go up one tooth on the CSS and you'll run cooler, higher speeds with same RPMs. My boot failed as well, but it was my fault, ran the engine with no coolant at all. My replacement boot has been good for 4-5000 miles now.
IMO those boots are a POS, prone to failure, mine failed but was repairable with gasket maker. They fatigue from heat and vibes under normal use. :(
Yes, stock gearing. I just picked up a 16t css that I will be installing when I get the new boot. What do you run in your rads? Just coolant and water? Ever tried water wetter?
Check your FI with I-beat....it may be running lean which makes it run hot.
I have a Power Commander V with Auto Tune. Shouldn't that make the bike run at the optimal afr since it replaces the o2 sensor and draws info from the egt's?
