Removing TE 310 Side Stand
2wheeler
What method did you use and not have to chase springs?
Got the side stand up. Lot of tension on the springs. Thought about unhooking the spring 'plate' from the frame then removing the stand bolt. Not sure about those springs tho.
The stand or the bolt? If all you want to do is take the auto-retract nub off the bolt you can do that with a Dremel and a file with everything in place on the bike. I can't think of any reason to trim the stand...its almost too short as it is and I end up using a block of wood in the garage or a rock out on the trail to put under it.
The stand itself. My stand was too long with the factory suspension settings. The bike was vertical almost leaning the other way with the stand down. Since, I have softened the preload of the shock and dropped the forks down some so my vertically challenged self can get on the thing. haha. Love the bike tho!
