Removing oil change symbol after performing oil change
withiam
Trying to find out how to remove the oil change symbol on the display. Tried the search function without successful results. I found the oil change warning interval instructions but it doesn't reveal how to remove the symbol.
Can someone point me in the right direction. Any help is appreciated.
withiam
Hold mode with key off, keep holding and turn on key, look for small letters (wr) in LRH corner, release and toggle until you get to (oil) hold until you see (----). release, toggle again until you see (yes), hold and release. Then just let it do it's thing. Sorry, but that's the best I can explaine it.
Mines an 09 TE, so follow the steps I posted. If you have trouble send a pm, I will call and talk you through it. It's the same as when you get the wrench ( service ) symbol.
I just applied your straight forward instructions and it couldn't be more simple. Thanks for taking the time to put it laymen's terms and offering your assistance.
withiam
