Removable clutch cover for water cooled 430
silverstreakNZ
So I've got a 87 wr430 . I want to fit a clutch cover with removable access . Does such a cover exist being removable cover and water cooled . Or being 4st are none of the removable covers have a water pump . Bit confused . Cover I have found is 98 te 410
Cheers
the only husqvarna clutch covers you can use that have the separate cover also have no provision for a water pump. so you are correct, husqvarna did not make what you need.
