silverstreakNZ
so according to this add this bike has a rekluse clutch , you rekon he means an auto one or a rekluse manual clutch kit ?
https://cincinnati.craigslist.org/mcy/5050622844.html
1982 Husqvarna WR430 - $2200 (Bridgetown)
Bike has been set up for vintage racing, upgrades include:
Lectron 40mm carb
Bored out one time
Forks and front disk brake from 1983 WR430
Cartridge Inserts in forks
Recluse Clutch
Vector Speedometer
the bike has a later clutch cover with the removable clutch cover part so may have a later clutch etc in it . do rekluse support a newer model that is interchangable with the bikes of that era ?
if i found one cheap enough id actually put one in the 82 cr500 purely so i could never stall it . its a bit of a pig with the 4 speed . and im not down with the big bore 500 "2nd" gear start . its got enough balls to just roll it on and drag most stuff off anyway
anyone got any insight into which one would be compatiable . given that all clutches are about the same size these days there must be some cross over that has a matching od and number of drive lugs etc
thoughts ?
Lectron 40mm carb
Bored out one time
Recluse Clutch
Vector Speedometer
thoughts ?
