TerryLee
I just bought a 2003 TE610 with 1300 miles on it. It was garaged for many years and not ran. So I changed plug, oil, coolant, battery, fuel, and cleaned carb the best I could. The problems I am having is the exhaust pipes are turning red hot very fast, a slight pop out of exhaust at deceleration, revs up great at idle but as soon as you kick it into gear and accelerate it wants to shut off. I really have to ride clutch and a lot of throttle to advance forward, after a short distance that goes away until the bike completely cools down. So...What have I found? Pulled new pug out, looks ok to me but might be leaning toward the lean end. Which might explain the red pipes. Also where the mufflers slip on the exhaust pipes there is some black residue and exhaust gas is slightly leaking at those unions. I just don't understand why it would be running lean or rich...the air screw has silicone over it for epa regs so I know it has not been adjusted from factory. This is my first Husqvarna and I need some help. Perhaps its just the nature of the machine. I so hope it is not the valves. Help Please!
