TahoeHusky
Hi all. New here, but Ive been lurking for a while and decided its time to ask the experts. So I got a 1985 cr500 6 speed model and it has the mini 6 motoplat in it. Ive just been generally restoring the bike. Including new chain and sprockets, rear wheel bearings, front brake pads, plastics, etc. Im trying to get lights on this badboy since I want it to be my enduro big bore.
According to my research the mini 6 has three light wires (yellow for headlight 35w 6 volts AC i think?, and a wire for blinkers and a one for tail light). Mine has the blue and black ignition wires then just one yellow wire so i dont know where the other wires are. I ran a snowblower light to it and grounded it and it lit up but pretty dim unless I revved it then it was bright.
I know I need a voltage regulator and I need to get a handlebar switch. But what is a recommended set up for this old motoplat? Everyone says just upgrade the stator but I was to save money. Is there a way to boost voltage to 12 DC to run led? Or what is the best output bulb i can run with this? i have a housing that will work so if i find the right bulb i can just use the existing housing. The light I have now is desgined for twelve volts i think so do I even need a regulator? Will the voltage or wattage ever jump above that and blow the bulb?
Everything on this bike is simple yet the electric system has got me confused. Sorry to ramble but thanks guys any and all info on this bike would be greatly appreciated!! Thanks
