Rear wheel pin/axle can't remove
husqv2500
I've tried banging it out with a hammer and prying it out with a crowbar but it's barely moving. Last time I did this it I remember it coming out a lot easier. is there an easy way to get this pin out??
Any input would be appreciated.
Unscrew the nut first ;-) Seriously though, maybe place a couple of 1 x 4's or spacers of some sort so your wheel is supported and taking load off the axle carefully spray some Boeshield or other lube so it can seep into the axle hole and not coat the brake rotor. I'de tap on it lightly with nut backed off with a block of wood, etc... If the nut is backed off, see if the wheel can move fore/aft. If so wiggle it sideways too as doing so may loosen the axle. Grease the axle well on reassembly!
