rear spring TE250 2010 (race sag)
sami
hello
i try to adjust rear shock preload and i dont get right race sag..100mm
my weight is 68kg without riding equipment.
is the spring too hard?
is the softer spring rigth answer my problem?
At 68kg, the you may need a softer spring. To to r a c e tech.com and use the calculator.
Modifiers:
Riding Type: Desert / Enduro / Trail
Age: Standard Age - Up to 44
Skill Level: Dirt Amateur
Height: Standard Height
Gas Tank: Standard Gas Tank
REAR SHOCK SPRINGS
Recommended Shock Spring Rate: 5.419 kg/mm (use closest available)
Stock Shock Spring Rate: Call kg/mm (stock)
Available SRSP 6228 Series Springs are:
RT SHK SPR 63.4x60.6x270 4.0kg - RT SHK SPR 63.4x60.6x270 6.4kg
what that mean 4.0kg,4,2kg,4,4kg?
how i can select rigth spring rate
