rear spring rates
paul-essex
dose anyone know the rear spring # ect
2010 te (uk) STD ? and set for what weight rider
as I am 95 kg plus riding gear dose anyone know what spring do I need
Hi Paul, sorry mate don't know the specs for the spring, Huskysport at Cheriton 01962 771122 will help you with the part numbers etc. I found the spring rate ok - I'm about 240lbs/109kgs with gear on - but the rear was set heavily over damped and compressed. The ride was hard and choppy.You might find backing these off and setting the sag will help no end. Cheers.
