My new Race Tech shock spring is rubbing on my swingarm on the lower right side down sorta by the rear brake master cylinder. In just a brief ride it significantly wore into a weld bead. The Race Tech/ Eibach (?) spring is larger in diameter and requires an adapter collar to use. I suspect the spring is made in U.S. dimensions and thus is sized differently than the stock metric one. Could be wrong on that.
Anyway, I don't want to grind any more meat off the swing arm, and I'm afraid to grind a bit on the bottom coil of the spring as the spring may rotate on it's perch(?) And I don't particularly want to hunt down a smaller dia. spring and spend another $100. or so... Anybody else run into this issue. I searched and didn't find anything on it. Approx. 5.7 rate spring.
