Rear shock 2009 txc
Neil Kleyn
Can I replace the bump stop without pulling the shock apart?
And whilst it's out is there any way I can change the oil myself? Or is it not really required
Thanks
Neil
To change the bump stop without disassembling the shock, you'd still need to release the nitrogen pressure for safety, and then you'd have to be able to hold the chrome shaft while heating and unscrewing the clevis... which can be VERY hot and tight. It's actually much easier and less likely to damage the components to just disassemble the shock the normal way. And, yes, you'd need to change the oil when doing so.
I'll add that the Sachs shocks from that era were very good IMO. I had a 2009 TE450 and a 2012 WR150 and the shocks were solid, easy to work on, and responded well to my tuning.
i would suggest a full rebuild w new seals while your at a it. i believe that Ohlins internals will fit the sachs shock too....
