Rear brake pin removal
mike54
Feeling like a clutz with this one guys - removed cotter pin, pad pin just spins but won't come out? Is there some kind of thread or something weird going on here? Shop manual just says "remove the cotter pin and slide out brake pin" but no sliding?! Help!
Just use a awl and hammer. A quick rap on the small end will unseat the collet, ball detant ..what ever it's called, then the pin will slide out . Same process to seat it back ...but hit the big end
As KP says... Punch and hammer from the outside to remove. There is a split bushing about 1/4" long set into a groove on the wheel side of the caliper pin which lightly presses into the caliper body.
Thank you, gentlemen. Got it out with a drift and a lump hammer in the end. Just did not want to budge at all.
