Rear brake light 2010 TE450
ChaosAD
Hi Guys
I have a TE 450 2010 awesome bike, however the back brake light is always on bright no mater what i do to the brakes. do you think its bad wiring or just the switch on the actual master brake cilinder ?
How would i test it ?
Thanks in adv!
Thanks for the reply CJ there is continuity from the swith when i apply the rear break and none when the break is not applied witch seems right, however when i test the continuity from the break light there is always continuity what could this mean a fuse or faulty connection on the break light ?
Pretty common for the front mini-switch to get pulled from its socket on the front master cylinder... then because the mini-switch is a "normal closed" switch and not depressed by the lever- the brake light is on all the time.
Check that
HUSKYnXJnWI you are the man, thank you so much as simple as that and its all sorted, the mini switch was lose and one i put it back my brake light works
Thanks again!
